Normal Topic System.ArgumentException with Message=Width and Height must be non-negative (Read 1425 times)
beetee
Aug 14th, 2019 at 11:24am
We get an exception with following details while opening a diagram. This is happening while opening a diagram with many nested diagrams inside. Version of Mindfusion dlls is 3.5.4.451.It is difficult to create a sample application. Similar issue is reported here and resolved as [url=[url]https://mindfusion.eu/Forum/YaBB.pl?num=1268662655/2][url]https://mindfusion.eu/...[/url][/url].
HResult=0x80070057
Message=Width and Height must be non-negative.
Source=WindowsBase
StackTrace:
at System.Windows.Rect..ctor(Double x, Double y, Double width, Double height)
at A.KY.K(DiagramLink P, Boolean K)
at MindFusion.Diagramming.Wpf.DiagramLink.GetBounds()
at MindFusion.Diagramming.Wpf.DiagramLink.MeasureOverride(Size availableSize)
at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
at System.Windows.UIElement.Measure(Size availableSize)
at A.LN.MeasureOverride(Size availableSize)
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionCont
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at App.Main()
beetee
Re: System.ArgumentException with Message=Width and Height must be non-negative
Reply #1 - Aug 14th, 2019 at 11:56am
Check if you haven't somehow created a link without points or with a negative StrokeThickness value. If by opening you mean loading a diagram's XML file, please attach the file here. If you are building it dynamically, attach a file saved before arranging and please post your layout code.
beetee
Reply #2 - Aug 21st, 2019 at 2:25pm
Hello Slavcho,
It was due to link without points.
Thank you for guiding in the right direction.
BT
