Normal Topic TouchUp event - which key is pressed (Read 2805 times)
sinisa
Oct 14th, 2019 at 2:26pm
Hello
I am using FPS virtual keyboard on touchscreen and on first pressing on button the OnKeyDown event is not triggered.
After second pressing OnKeyDown event is triggered.
Therefore I've added TouchUp event, which is correctly after first pressing on button triggered.
However, I cannot find the pressed button in the arrived TouchEventArgs.
How can I find out the pressed key in the TouchEventArgs?
Thank you.
Re: TouchUp event - which key is pressed
Reply #1 - Oct 14th, 2019 at 2:59pm
Do you mean you are using original keyboard by FreezePro Software? You might check if more recent Mindfusion version isn't handling that better in your set up. Otherwise I guess try looping over keyboard.Layout.Keys and compare each key's coordinates with the touch position.
