Normal Topic Diagram Events ! (Read 2851 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Diagram Events !
Oct 18th, 2019 at 11:50am
      I've subscribed to Event.nodeModified and Event.linkModified events. When a node is moved, Event.nodeModified is called. If a link is moved, Event.linkModified is called. When a node is moved links also gets modified in the UI, but Event.linkModified is not called. Is this the correct behavior?
Kannan
Online
Re: Diagram Events !
Reply #1 - Oct 21st, 2019 at 6:43am
Correct or not, that's how these events have been working in our various platforms for many years; let's say it's more of a gray area Smiley If you need to treat direct and indirect modifications of a link in same way, I guess loop over node's links and call your link-specific handler for each one.
Kannan Thirumal
Senior Member
Reply #2 - May 11th, 2020 at 7:32am
I've subscribed to nodeModifying event like this. When one node is selected and moved, this event is called but more than one node is selected and moved, nodeModifying event is not called. May I know why?
    this.diagram.addEventListener(Event.nodeModifying, (sender, args) => {
      var canvasBounds = sender.getBounds() as Rect;
      var nodeBounds = args.node.getBounds() as Rect;
      if (nodeBounds.x < canvasBounds.x || nodeBounds.y < canvasBounds.y) {
        args.setCancel(true);
Kannan
Online
Reply #3 - May 11th, 2020 at 3:57pm
There's the selectionModifying event raised when there are multiple items being moved or resized.
Kannan Thirumal
Senior Member
Reply #4 - May 12th, 2020 at 6:29am
Hi Slavcho,
It works fine. Thank you!
Kannan
Kannan Thirumal
Senior Member
Reply #5 - Sep 3rd, 2020 at 5:36pm
I've a different scenario like below,
* There are 3 nodes. In that 2 nodes are connected by a link (Attached Image - Link Before Node Move.png)
* Now, 3rd node is drag and dropped over the link (Attached Image - Link After Node Move.png)
Now the link got adjusted but the nodeModified event raised for the 3rd node but not able to capture the changes of the link.
May I know how to handle this?
Kannan
Slavcho wrote on Oct 21st, 2019 at 6:43am:
Online
Reply #6 - Sep 4th, 2020 at 11:07am
On other platforms of ours that would raise LinkRouted event, but seems it's not available in JS version. We'll have it in mind for next release.
