Normal Topic Image Fails to Save (Read 1289 times)
MindFusionUser47
Image Fails to Save
Nov 4th, 2019 at 4:33am
Are there reasons an image would fail when trying to save? The error message is "parameter not valid".
Image image = diagram.CreateImage();
image.Save(filename + ".png", ImageFormat.Png);
image.Dispose();
The code fails at the Save part
« Last Edit: Nov 5th, 2019 at 5:12am by MindFusionUser47 »
Re: Image Fails to Save
Reply #1 - Nov 4th, 2019 at 6:17am
The bitmap size might be reaching some limit of GDI+, or specifically of the PNG encoder. You could export a scaled down bitmap or split into smaller bitmaps, or otherwise use different formats like SVG or PDF.
