Normal Topic Invisible node (Read 1371 times)
Anna Malashkina
Invisible node
Nov 26th, 2019 at 12:52pm
Is it possible to draw invisible "dummy" node? So that the link to this node and the link out of this node look like one single not interrupted link?
Re: Invisible node
Reply #1 - Nov 26th, 2019 at 2:01pm
You could set node's Visible property to false (or Transparent to true for ShapeNode).
Anna Malashkina
Re: Invisible node
Reply #2 - Nov 27th, 2019 at 12:56pm
In this case I'll have an empty space between ends of incoming edges and starts of outcoming edges. But I would like to have ending of incoming edges and starting of outcoming ones in exactly one point.
Re: Invisible node
Reply #3 - Nov 28th, 2019 at 6:44am
You could create very tiny nodes, or add an AnchorPoint to larger node's center. Another possibility is calling links' setStartPoint and setEndPoint with center' coordinates.
