Normal Topic Spreadsheet for Java, V1.0.3 (Read 2079 times)
Feb 24th, 2020 at 4:02pm
We have released version 1.0.3 of MindFusion Spreadsheet for Java. The new version includes:
Localization
The standard forms from com.mindfusion.spreadsheet.standardforms package can now be localized via XML translation files containing UI labels for respective language. To enable localization, call the new setLocalizationInfo method of the Workbook class and provide path to the XML file. Translations for German, Spanish, French, Korean, Portuguese, Russian, and Chinese can be found inside the localization folder of the library's distribution.
  • Drag-select cells to enter a range while editing in formula bar.
  • worksheetCellParsing event lets you replace values entered by users or change their data type.
  • ExcelImporter fixes and optimizations.
  • Auto-fill no longer changes values of non-editable cells (due to property or validation events).
https://mindfusion.eu/JSpreadsheet.zip
