Hot Topic (More than 10 Replies) Dock Control Titlebarbuttons (Read 11964 times)
Online
Re: Dock Control Titlebarbuttons
Reply #15 - Jun 25th, 2020 at 1:15pm
DockItem's DockStyle is actually copied from parent if you add it as a tab (the center tabbed icon from target overlay) to a container. I guess you will see DockStyle values change if you move the item between containers on different sides of the dock control. Otherwise if you examine DockStyle value of all tabs in same container, it should be the same for all and equal to container's one.
goblue
Reply #16 - Jun 25th, 2020 at 9:50pm
Hi Slavcho, thanks for the tip. However, DockItem's parent seems to be always null. After some investigation, I realized what I need is the Dock property of the non-public property DockWindow. I was able to get it using Reflection but it would be nice if it can be more easily accessed.
On a different note, I found another issue with the control box: if a DockItem is loaded using LoadFormXml and DockStyle == None, when the user drags it and makes it a tabbed dock, the control box disappears.
Online
Reply #17 - Jun 29th, 2020 at 5:44am
We could not reproduce, but our developer redid titlebar buttons altogether to not keep local copies for each dock panel, it should not be possible to duplicate or lose ones here -
https://mindfusion.eu/_temp/dock_window.zip
DockWindow is now public too.
There are some API changes if you use custom buttons, you should take position and parent properties from event arguments instead of button themselves.
goblue
Reply #18 - Jun 29th, 2020 at 9:24pm
Slavcho, all is working now. Thank you for your help!
