Hot Topic (More than 10 Replies) Dock Control Titlebarbuttons (Read 11956 times)
Ktmr
Mar 27th, 2020 at 9:02am
I am trying your dock control component. Titlebarbuttons are repeating when I add new dockitem. Same problem in your sample project.
How can I solve this problem?
Online
Re: Dock Control Titlebarbuttons
Reply #1 - Mar 27th, 2020 at 10:05am
Older assemblies from zip file here seem to work correctly, try using them for time being (some event argument classes are named differently in older version though) -
https://mindfusion.eu/samples/winforms/ui/DockControl.CS.zip
Our developer will try to fix it in next few days.
Ktmr
Reply #2 - Mar 27th, 2020 at 10:17am
Ok. Thank you for helping.
Online
Reply #3 - Mar 31st, 2020 at 2:49pm
This build should fix it -
https://mindfusion.eu/_temp/dock_duplicate.zip
Ktmr
Reply #4 - Apr 22nd, 2020 at 7:40am
Unfortunately, the problem still continues while merging pages to one tab.
Iva_P
Reply #5 - Apr 22nd, 2020 at 9:48am
We tested with the solution that demonstrated the problem before the fix - the Visual Studio mock-up project. We added two buttons - one that adds more tabs, the other removes them - one by one. No problems showed up.
I've uploaded that project here:
https://mindfusion.eu/samples/winforms/DockControl.CS.rar
Please try it and let me know if that's what you meant.
Kind Regards,
Iva
« Last Edit: Dec 26th, 2020 at 5:56pm by Forum Admin »
Ktmr
Reply #6 - Apr 22nd, 2020 at 11:02am
It is working now. Thank you very much.
goblue
Reply #7 - Jun 1st, 2020 at 9:44pm
I'm having the same issue even after upgrading to the build on 3/31. In the sample project posted above, if you close both tabs ("Toolbox" and "Tabbed Document") then reopen them, you still get two control boxes.
BTW, is there a way to change DockStyle without having to remove and add a DockItem back?
Online
Reply #8 - Jun 2nd, 2020 at 10:14am
Our developer will check in a bit.
Online
Reply #9 - Jun 3rd, 2020 at 12:28pm
We can't see a way to change item's style without removing / adding, we'll have it in mind for next release.
goblue
Reply #10 - Jun 4th, 2020 at 7:11pm
Thank you very much for the quick response! The issue is now gone. Another feature I'd like to request -  set DockItem's location on the screen when DockStyle=None Grin
Online
Reply #11 - Jun 5th, 2020 at 3:00pm
Adding undocked item actually creates a top-level form, you could move it like this for time being -
var item = new DockItem() { Header = "new", Id = "new" };
item.DockStyle = DockStyle.None;
item.Content = GetContent("test");
dockControl1.Items.Add(item);
var l = Application.OpenForms.Count - 1;
Application.OpenForms[l].Left = 400;
Application.OpenForms[l].Top = 400;
We'll try to add proper API for that in next release.
goblue
Reply #12 - Jun 20th, 2020 at 12:18am
Thank you. Found another minor issue: after LoadFromXml, all the control boxes disappear.
Online
Reply #13 - Jun 23rd, 2020 at 12:01pm
this build should fix it -
https://mindfusion.eu/_temp/dock_xml.zip
goblue
Reply #14 - Jun 23rd, 2020 at 2:45pm
Thank you, Slavcho. There is another bug: when the user drags a window and makes it a tabbed doc. The DockStyle property doesn't set to Fill. It would randomly set to Left, Right, Top or Bottom(seems to be related to the previous DockStyle) but not Fill.
