We have released version 3.4 of MindFusion JavaScript Diagram library. It contains the following new features and improvements:
React supportThe DiagramView React component allows integrating the MindFusion.Diagramming API into React applications. It renders a Diagram instance assigned to "diagram" prop as its model. Most diagram properties can be set from JSX, and all diagram events can be handled through JSX syntax as well. For more information, see the
Integration with React help topic.
Vue.js supportThe diagram-view Vue.js component allows integrating the MindFusion.Diagramming API into Vue.js applications. It renders a Diagram instance assigned to "diagram" prop as its model. Most diagram properties can be set from the vue template, and all diagram events can be handled through the v-on directive as well. For more information, see the
Integration with Vue.js help topic.
Angular supportThe diagram-view Angular component allows integrating the MindFusion.Diagramming API into Angular applications. It renders a Diagram instance assigned to "diagram" property as its model. Most diagram properties can be set from the html template, and all diagram events can be handled through event binding syntax as well. For more information, see the
Integration with Angular help topic.
Video nodesVideoNode objects display video streams, along with UI elements to play, pause, seek and change volume. Call node's setVideoLocation method to specify its video URL. Auto-playing is not supported at this time, and the video can be started only by users clicking the play button. VideoNode is built around Video component, which can also be used in CompositeNode templates.
Miscellaneous- Improved automatic routing of links.
- More precise scrolling with TableNode scrollbar thumb.
Distribution for the latest version can be downloaded here, or from the
clients area on our site:
https://mindfusion.eu/JsDiagramTrial.zipUpdated scripts are also available as
diagram-library NPM package.
