Normal Topic Diagramming for JavaScript, V3.4 (Read 2644 times)
Apr 6th, 2020 at 3:10pm
We have released version 3.4 of MindFusion JavaScript Diagram library. It contains the following new features and improvements:
React support
The DiagramView React component allows integrating the MindFusion.Diagramming API into React applications. It renders a Diagram instance assigned to "diagram" prop as its model. Most diagram properties can be set from JSX, and all diagram events can be handled through JSX syntax as well. For more information, see the Integration with React help topic.
Vue.js support
The diagram-view Vue.js component allows integrating the MindFusion.Diagramming API into Vue.js applications. It renders a Diagram instance assigned to "diagram" prop as its model. Most diagram properties can be set from the vue template, and all diagram events can be handled through the v-on directive as well. For more information, see the Integration with Vue.js help topic.
Angular support
The diagram-view Angular component allows integrating the MindFusion.Diagramming API into Angular applications. It renders a Diagram instance assigned to "diagram" property as its model. Most diagram properties can be set from the html template, and all diagram events can be handled through event binding syntax as well. For more information, see the Integration with Angular help topic.
Video nodes
VideoNode objects display video streams, along with UI elements to play, pause, seek and change volume. Call node's setVideoLocation method to specify its video URL. Auto-playing is not supported at this time, and the video can be started only by users clicking the play button. VideoNode is built around Video component, which can also be used in CompositeNode templates.
  • Improved automatic routing of links.
  • More precise scrolling with TableNode scrollbar thumb.
Updated scripts are also available as diagram-library NPM package.
« Last Edit: Nov 30th, 2020 at 1:08pm by Forum Admin »
