Normal Topic Export to Visio (Read 1599 times)
Santosh P
Export to Visio
May 14th, 2020 at 5:17pm
I am trying to evaluate JavaScript controls to draw diagrams for one of my projects. I am also looking at an ability to export the same in Visio. Please guide me to correct article\tutorial to speed up the evaluation process.
I am looking out for rendering diagram on the fly and then exporting that diagram to visio.
Re: Export to Visio
Reply #1 - May 15th, 2020 at 6:12am
We have VisioExporter class in .NET and Java versions of the component -
https://www.mindfusion.eu/onlinehelp/mvcdiagram/index.htm?T_MindFusion_Diagrammi...
If you don't mind running them on your server, you could export to Visio on server side and return a file response to client. E.g. the ASP.NET MVC  library distribution includes a PDF export sample project, replace the PdfExporter used there with a Visio/2013/Exporter instance.
Santosh P
Re: Export to Visio
Reply #2 - May 16th, 2020 at 2:19pm
Hi Slavcho,
Thanks for a quick response. Can you please guide me to "ASP.NET MVC  library distribution" as mentioned by you so that I can download and play with it to explore visio option.
Santosh
Re: Export to Visio
Reply #3 - May 17th, 2020 at 7:09am
Hi Santosh,
You can find it here -
https://mindfusion.eu/MvcDiagramTrial.zip
