Normal Topic Stop key highlighting for password entry (Read 2530 times)
bsea
Aug 10th, 2020 at 3:10pm
Is there a way to turn off the key highlighting when entering a password for security purposes?
The attached image has the "T" key highlighted when entering a password.  I would like to disable that feature for the password box.
Online
Re: Stop key highlighting for password entry
Reply #1 - Aug 10th, 2020 at 4:05pm
You could remove IsMouseOver and IsPressed triggers from data templates of all key types. Our developer will check if there's an easier way.
Online
Reply #2 - Aug 11th, 2020 at 4:49pm
This build adds PasswordMode property -
https://mindfusion.eu/_beta/vkb_password.zip
bsea
Reply #3 - Aug 13th, 2020 at 2:10pm
Hi Slavcho,
Thanks for the update, but I'm having a little difficulty getting my references working again with the updated DLLs.  What procedure should I use to remove the old installation of the Virtual Keyboard control?  Originally, I used the msi installer.  Should I uninstall that first before overwriting the DLLs?
Online
Reply #4 - Aug 13th, 2020 at 3:10pm
It should be enough to unzip into some folder and add its path to reference paths list in project options. Alternatively select the mindfusion.* references in solution explorer and delete them, then add them anew browsing to latest assemblies. Also check property window when reference is selected - make sure "use specific version" is disabled.
