Normal Topic Get Shape Default Dimension (Read 2281 times)
bertbell
Aug 15th, 2020 at 12:45am
I am adding ShapeNode objects to a diagram programmatically using a ShapeLibrary.  Is there any way to get the default Shape object dimension?  The shapes are drawn using  Lines, rectangles and arcs if that matters.
I would like it to be the same size as the ShapeNodes added via drag and drop.
Re: Get Shape Default Dimension
Reply #1 - Aug 15th, 2020 at 12:22pm
Try ShapeListBox.getDefaultShapeSize() or NodeListView.getDefaultNodeSize(), depending on which control you drag from. You could also change these to your preferred size.
