Normal Topic Modify exiting events (Read 3034 times)
Ambieremm
Sep 14th, 2020 at 7:02pm
Hi, I am using jplaner to create evetns and saving them in a database, I can make them and show them but i couldn´t figure out how to change the text or date of the one that already exist. I will show you my code. I m using the dual view sample as a base
Ambieremm
Re: Modify exiting events
Reply #1 - Sep 14th, 2020 at 7:03pm
More screencaps
Reply #2 - Sep 15th, 2020 at 4:58am
If you need to save immediately when an item is modified, handle the itemModified event. You could associate your appointments with database records by setting Id or Tag property to record's primary id. Then you can run UPDATE statements instead of INSERT when saving if you find the record exists. In other direction you can search Schedule.Items for appointment with respective id, change its date and text if already existing, or create a new one otherwise.
Ambieremm
Reply #3 - Oct 20th, 2020 at 2:42am
HI, now I can change the date by  draging the appointment created but i can´t figure how to make the program register the name changing
Reply #4 - Oct 20th, 2020 at 4:58am
Try the CalendarListener.itemInplaceEdited event.
