Normal Topic The right-click menu controls the copy, paste or delete operations of the ShapeNode (Read 1741 times)
JackPan
Sep 28th, 2020 at 6:13am
Hi, there Smiley
How to realize that after selecting this ShapeNode, click the right mouse button to pop up a menu option to delete this ShapeNode.
Any assistance would be appreciated.
Cheers,
Jack
Lyubo
MindFusion team
Re: The right-click menu controls the copy, paste or delete operations of the ShapeNode
Reply #1 - Sep 28th, 2020 at 7:05am
You can use the built-in WPF ContextMenu control and show it from a NodeClicked event (check for which button was pressed from the event arguments object). You can then handle the ContextMenu item's click event to delete the node, by using the Remove method on the Diagram.Nodes collection.
Lyubo
MindFusion
JackPan
Reply #2 - Oct 19th, 2020 at 12:31pm
Thank you very much, Lyubo. Smiley
