The crash happens on your device, because the expected API level is 26 (Android 8.0+) for Google Play store compatibility. We'll have in mind to add a runtime backwards compatibility check in the next release.
Mandy wrote on Oct 27
th, 2020 at 5:03am:
2.The node cannot select and icon not display when set the Icon load image from URL.
As I wrote in my previous post, I am unable to reproduce the issue in your test project. Images load and selection works. As I can see in the provided video above, images are loading too, and nodes are being selected. Do you mean some other issue?
Quote:3.In any mode, I need select multiple node and node can not be drag and drop.
4.Can you provide a behavior that can zoom in/zoom out the diagram and select multiple node without using the compass ?
You will need to use a custom behavior class to achieve this functionality. Please provide us with the expected way to distinguish between selection / panning / zooming interactions, so we can assist you further with implementation.
Quote:5.What event will happen after i selected multiple nodes ?
There's the Diagram.SelectionChanged event, which is raised when an item is added to or removed from the selection.
Lyubo
MindFusion
