Hot Topic (More than 10 Replies) Add button in cell. (Read 8815 times)
Re: Add button in cell.
Reply #15 - Dec 21st, 2020 at 6:38am
Showing it in the edit UI should be possible via InplaceEditStarting event, but then the button will appear only for the currently active cell (one you can type into). Otherwise styling cells to look as in screenshot above can be done like this -
var cell = activeSheet.Cells["A1"];
cell.Style.Background = new LinearGradientBrush(
    Colors.DarkSlateGray, Colors.Gray, 30);
cell.Style.BorderTopSize = 2;
cell.Style.BorderBottomSize = 2;
cell.Style.BorderLeftSize = 2;
cell.Style.BorderRightSize = 2;
cell.Style.BorderTopBrush = Brushes.Black;
cell.Style.BorderBottomBrush = Brushes.Black;
cell.Style.BorderLeftBrush = Brushes.Black;
cell.Style.BorderRightBrush = Brushes.Black;
cell.Style.HorizontalAlignment =
	MindFusion.Spreadsheet.Wpf.HorizontalAlignment.Center;
cell.Style.VerticalAlignment =
	MindFusion.Spreadsheet.Wpf.VerticalAlignment.Middle;
David Chiang
Reply #16 - Dec 22nd, 2020 at 5:38am
Thanks for the answer. I can using hyperlink to hide the data behind it.
                                   string[] ev = columnsList[j].Split("^#^");
                                   var cell = activeSheet.Cells[j, x + 1];
                                   cell.Style.HorizontalAlignment = MindFusion.Spreadsheet.Wpf.HorizontalAlignment.Center;
                                   cell.Style.TextBrush = new SolidColorBrush(Color.FromRgb(240, 240, 240));
                                   cell.Data = ev[0];
                                   cell.SetHyperlink(HyperlinkType.WebAddress, ev[3] + "?" + ev[4] + dataRow[ev[1]].ToString(), "");
                       workbookView.HyperlinkClicked += (sender, args) => showWindow(args.Cell.Hyperlink.Target.ToString());
David Chiang
