Normal Topic Diagramming for JavaScript, V3.5.2 (Read 1501 times)
Jan 6th, 2021 at 11:14am
We have released version 3.5.2 of MindFusion JavaScript Diagram library. It contains the following new features and improvements:
Topological Layout
TopologicalLayout applies graph topological ordering to the diagram (topological ordering of a graph is one where link's origin node is placed before link's destination node). The layout algorithm arranges nodes in a row or a column, depending on the value of the direction property, in such a way that there are no backward links when the graph is acyclic. If the graph contains cycles, the algorithms selects ordering with as few backward links as possible. Links that connect non-adjacent nodes are rendered as arcs, whose amplitude is proportional to the distance between respective connected nodes. Forward links are rendered at one side of the nodes and back links are rendered at the opposite side. All that makes it easy to discern graph features such as overall flow direction, cycles and nested cycles.
  • The diagram canvas now automatically expands to fill the area freed up when a scrollbar auto-hides.
  • Fixed Overview flickering when the tracker rectangle is being dragged near the control's borders.
Updated scripts are also available as diagram-library NPM package.
