Normal Topic Multiple Item Select - Only Select Nodes (Read 966 times)
alukes
Jun 29th, 2021 at 12:49am
I saw this method: https://mindfusion.eu/Forum/YaBB.pl?num=1245076133/2, and I changed it work in Javascript, but the function is never called. My version below.
private void OnSelectionChanged(object sender, EventArgs e)
     if (!inSelChanged)
           inSelChanged = true;
           while (diagram.Selection.Links.Count > 1)
                 diagram.Selection.Links[0].Selected = false;
           inSelChanged = false;
private bool inSelChanged;
My Version:
function  onSelectionChanged(sender,args)
     if (!inSelChanged)
var inSelChanged = false;
diagram.addEventListener(Events.selectionChanged, onSelectionChanged);
Javascript doesn't complain, it simply ignores the multiple item selection.  What am I missing?   Thanks
Re: Multiple Item Select - Only Select Nodes
Reply #1 - Jun 29th, 2021 at 2:20pm
That event's not available in the JavaScript library -
https://www.mindfusion.eu/onlinehelp/jsdiagram/index.htm?T_MindFusion_Diagrammin...
If you need to prevent users from selecting links altogether, try setting links' Locked property.
