Normal Topic Custom cell editors (Read 4225 times)
divis_dev
Custom cell editors
Oct 29th, 2021 at 11:51am
I tried to use a JComboBox as a custom cell editor and experienced some problems. The combo box works until the default text editor is used for the first time. After the first text edit, the text editor starts throwing IllegalComponentStateExceptions.
The problem seems to be that the GridView never resets the currentTextEditor reference to null. So even when processing an edit event for the ComboBox, there is a currentTextEditor reference set from another/previous cell edit.
In endEdit currentEditor is set to null, but currentTextEditor is not...
Another problem in endEdit might be
Code (Java)
if (newValue instanceof String)
  lastIO.setEditedText(newText);
because newValue != newText.
The attached file contains a small example.
Re: Custom cell editors
Reply #1 - Oct 29th, 2021 at 12:36pm
Thanks for letting us know. Our developer will investigate.
Reply #2 - Nov 2nd, 2021 at 7:43am
New jar here should fix that -
https://mindfusion.eu/_temp/JPack_editor.zip
If you build from source code, our fix is replacing this line in beginEdit -
if (currentEditor instanceof JTextComponent)
    currentTextEditor = (JTextComponent)currentEditor;
with this one -
currentTextEditor = Helper.as(currentEditor, JTextComponent.class);
(that accounts for incorrectly translated currentTextEditor = currentEditor as TextBoxBase assignment from our original C# code, which also nulls currentTextEditor when using a custom editor).
divis_dev
Reply #3 - Nov 2nd, 2021 at 1:47pm
Hi Slavcho,
thank you for your quick response.
The new beginEdit works fine, but there is one more thing in endEdit that seems to be a bug.
Code (Java)
should be replaced with
Code (Java)
  lastIO.setEditedText((String)newValue);
because newText is allways empty if currentTextEditor is null.
Which it is, when we use custom editors.
What do you think?
Best regards,
Stefan
Reply #4 - Nov 3rd, 2021 at 8:18am
Value from your custom editor is set correctly on next line (cell.setData...newValue). The newText assignment seems would be incorrect if custom editors return strings, which should be fixed here -
If you build the jar from source code, our fix is in attached diff, setting newText before validations code so it's used there too. The diff contains one other fix we've found in our C# EndEdit, for comparing values from custom editors.
