Normal Topic Fractal layout, displaying subordinate nodes clockwise (Read 1051 times)
danesh
Nov 1st, 2021 at 3:09pm
Iam using the fractal layout currently like this:
Code (Javascript)
var layout = {
	fractal: new MindFusion.Graphs.FractalLayout()
layout.fractal.root = diagram.nodes[0];
diagram.arrange(layout.fractal);
Does the fractal layout have a behaviour where child nodes are displayed around the parent node in a clockwise fashion?
By 'clockwise fashion' I mean in the order that nodes are added to the diagram using diagram.addItem(); as I am looping over some nodes and adding them to the diagram but as soon as I arrange them using fractal layout, they are placed in a random order around the parent.
Thank you
Kind regards
Danesh
Online
Re: Fractal layout, displaying subordinate nodes clockwise
Reply #1 - Nov 1st, 2021 at 3:45pm
From what I remember, you build the library yourself from source code - try replacing childCircles.sort(compareRadius) call in FractalLayout.js with your own sort criteria. Alternatively, if you comment that line out, it should use the order of links from parent to child nodes.
