Normal Topic Diagramming for WPF, V3.8.1 (Read 1329 times)
Jan 13th, 2022 at 12:48pm
We have released version 3.8.1 of WPF Diagram control. It contains the following new features and improvements:
.NET 6 assemblies
The distribution now includes assemblies for .NET 6. Automatic VS toolbox integration is not available at this time; you must add diagramming.wpf assembly references to the project manually or through Nuget, and then add corresponding elements to Xaml markup for the various controls from the library.
  • ArrangeAsync method is now available in CoreCLR assemblies (.NET Core 3 and 5+ versions).
  • The EnumAllPaths method of PathFinder yields each path immediately when found.
  • Fixed link-drawing exceptions when both TableNode and its Rows have their AnchorPattern set and ConnectionStyle is set to Both.
Updated assemblies are also available as MindFusion.Diagramming.Wpf NuGet package.
