Normal Topic Diagramming for Java Swing, V4.6.1 (Read 1691 times)
Feb 17th, 2022 at 9:17am
We have released version 4.6.1 of JDiagram. It contains the following new features and improvements:
TableNode improvements
  • The CaptionBackBrush property lets you customize the fill of table's caption bar.
  • Tables can be custom-drawn by setting their CustomDraw property and handling the drawNode event.
  • Table cells can be custom-drawn by setting the CellCustomDraw property and handling the drawCell event.
  • Fixed thick appearance of caption divider line when using CellFrameStyle.Simple.
TreeViewNode improvements
  • The Brush property of TreeViewItem allows assigning different backgrounds to individual items.
  • The ShowLines property lets you toggle visibility of items' connecting lines.
Fixed exception when serializing LinkLabel in JSON format.
Distribution for the latest version can be downloaded here, or from the clients area on our site.
https://www.mindfusion.eu/JDiagramTrial.zip
Updated JAR is also available at the Maven Central Repository:
https://search.maven.org/artifact/eu.mindfusion/diagramming
