Normal Topic Unable to set width for LinkLabel (Read 1767 times)
venkatrjv131
Aug 3rd, 2022 at 1:12pm
how can i set the width for linklabel. Instead of showing 2 words per line
Here is code:
const link = factory.createDiagramLink(new Point(x, y), new Point(x + width, y + height));
for (let l = 0; l < texts.length; l++) {
const subLabel = <any>link.addLabel(texts[l]);
subLabel.relativeTo = 1;
subLabel.enableWrap = true;
subLabel.maxWidth = 15;
subLabel.fitInBounds = true;
subLabel.index = 0;
subLabel.horizontalOffset = sp.x + 5;
subLabel.verticalOffset = sp.y;
subLabel.horizontalAlign = MindFusion.Diagramming.Alignment.Near;
subLabel.verticalAlign = MindFusion.Diagramming.Alignment.Center;
Can you help me out
Re: Unable to set width for LinkLabel
Reply #1 - Aug 3rd, 2022 at 3:28pm
If you mean you need to set larger widths, try scripts from new build here -
https://mindfusion.eu/_beta/jsdiag423.zip
venkatrjv131
Reply #2 - Aug 3rd, 2022 at 3:40pm
Thanks for reply @Slavcho,
But how to set width using ur code?
Reply #3 - Aug 3rd, 2022 at 3:45pm
Just replace the diagram scripts with ones from the archive, you shouldn't have to change any of your code if you are on a current version.
venkatrjv131
Reply #4 - Aug 3rd, 2022 at 5:11pm
Code not working with new scripts
Reply #5 - Aug 3rd, 2022 at 6:37pm
In what way is it not working? What version of the control were you using before trying v4.2.3 scripts?
venkatrjv131
Reply #6 - Aug 4th, 2022 at 4:06am
Current version is 3.3.2,
after upgrading to v4.2.3 the code result the same output.
Reply #7 - Aug 4th, 2022 at 6:12am
Have you set larger maxWidth? that's what these scripts should help with. Otherwise you can't set width smaller than longest word in label's text, as labels can only wrap at word boundaries at this time.
