Hot Topic (More than 10 Replies) Group - attach without resize (Read 2092 times)
Konstantin Vasilev
Aug 23rd, 2022 at 5:10am
Hello.
I would like to know how to attach an element to a group so that this element's size won't change if the master item gets resized?
Let's say I have a center point in my element and I want it to stay in the same position (relatively) regardless of the master size.
It looks like from all "Attach" methods none really fits this need - AttachToCorner and AttachToSideMiddle force my element to be in certain position I can't modify, AttachToEdges and AttachProportional will resize my element if the master node is resized.
It also seems that I can't use custom logic for the "attach" method since none of the methods suits my needs and AttachedNodes collection is a readonly collection.
Please advise.
Re: Group - attach without resize
Reply #1 - Aug 23rd, 2022 at 9:54am
AttachToCorner and AttachToSideMiddle should work, and possibly AttachToEdges if you specify just one horizontal and one vertical edge. They do not force attached nodes to the specified point, but record the initial offset from it and should preserve it when master node is moved or resized.
Konstantin Vasilev
Reply #2 - Aug 25th, 2022 at 10:52pm
Thank you for the reply. Unfortunately, both AttachToSideMiddle and AttachToCorner didn't work for me. I also tried to use the AttachToEdges method and supply it with the closest edges to my elements, but had no luck with it - my elements just didn't stick to their original relative position.
Reply #3 - Aug 26th, 2022 at 6:55am
Please post your code. E.g. the icons in this demo page are ShapeNodes attached to table's bottom left corner, preserving relative positions and not resizing -
Reply #4 - Aug 26th, 2022 at 1:38pm
Or did you mean you do not need preserving absolute offsets, but specify positions as fractions of width / height as in 'proportional' attachment type, just without resizing?
Konstantin Vasilev
Reply #5 - Aug 29th, 2022 at 4:55pm
Yes, I need to preserve the relative position of attachment in percent of master item's height/width, without resizing the attached item itself.
Reply #6 - Aug 30th, 2022 at 4:51pm
Try new overloads here -
https://mindfusion.eu/_beta/wpfdiag383.zip
DiagramNode.AttachTo(node, percentX, percentY);
Group.AttachToFractionalPosition(node, percentX, percentY);
Konstantin Vasilev
Reply #7 - Sep 5th, 2022 at 1:45pm
Seems to be working fine.
Thank you!
Do you have an ETA of when the 3.8.3 is going to be released?
Reply #8 - Sep 6th, 2022 at 8:34am
We plan it for mid-November.
Konstantin Vasilev
Reply #9 - Sep 7th, 2022 at 2:11pm
Is there any way to add this method before November? Are there any alternative ways to achieve this?
I can write any custom code if necessary.
Reply #10 - Sep 8th, 2022 at 6:10am
You already have it in assemblies above, just use them? That's only new thing there since 3.8.2 release from month ago, so should be stable enough.
Konstantin Vasilev
Reply #11 - Sep 8th, 2022 at 11:41pm
Ok, sounds good. Thanks for your help!
