Normal Topic SvgExporter: exportString: small offset in the y-axis on text (Read 1463 times)
Mindfusion User
Aug 23rd, 2022 at 9:55am
When we export our diagram to a SVG string with SvgExport.exportString(diagram), and convert it to a Blob URL in order to download it as an SVG, we notice that the text within the diagram SVG has a small offset in the y-axis.
An image of the exported diagram is added in the attachment.
Below is our code to export the diagram and convert it to a downloadable svg image:
var exporter = new MindFusion.Diagramming.SvgExporter();
var svgElement = exporter.exportString(diagram);
const blob = new Blob([svgElement], { type: "image/svg+xml" });
const url = URL.createObjectURL(blob);
downloadURI(url, "exportedDiagram.svg");
function downloadURI(uri, name)
    var link = document.createElement("a");
    link.download = name;
    link.href = uri;
    document.body.appendChild(link);
    link.click();
    document.body.removeChild(link);
    delete link;
Kind regards!
Re: SvgExporter: exportString: small offset in the y-axis on text
Reply #1 - Aug 23rd, 2022 at 12:14pm
New build here should fix that -
https://mindfusion.eu/_beta/jsdiag423.zip
Kind regards,
Mindfusion User
Reply #2 - Aug 24th, 2022 at 11:44am
Hi Slavcho,
Yes, now everything is positioned perfect! Thank you!!
Kind regards
Mindfusion User
Reply #3 - Aug 24th, 2022 at 12:11pm
Hi Slavcho,
Is it possible that in the new Beta version of your last reply, the Styled text character 'newline' ( = '<br />') is not supported anymore?
In the attachment are an older version of MF and the Beta version result shown.
The Shapenodes with a newline in it show in the new Beta version no text .
Note: The older MindFusion version could also allow '</br>' as a new line.
Kind regards.
Reply #4 - Aug 25th, 2022 at 8:53am
Our bad, new build should fix it -
Kind regards,
Mindfusion User
Reply #5 - Sep 1st, 2022 at 6:27am
Great! Thank you!
