Normal Topic JPlanner BaseList.remove fails to check presence of item to be removed (Read 1671 times)
bas_pharmapartners
Aug 31st, 2022 at 4:31pm
Observed location of bug:
com.mindfusion.common.BaseList.remove(Object)
Condition for reproduction:
List does not contain the element to be removed.
Observed behavior:
Method throws java.lang.ArrayIndexOutOfBoundsException.
Specified behavior (per java.util.Collection.remove(Object)):
Method returns false.
Tested with:
JPlanner 2.1.3
Stacktrace:
java.lang.ArrayIndexOutOfBoundsException: -1
     at java.util.ArrayList.elementData(ArrayList.java:424)
     at java.util.ArrayList.remove(ArrayList.java:501)
     at com.mindfusion.common.BaseList.doRemove(Unknown Source)
     at com.mindfusion.common.BaseList.remove(Unknown Source)
Reproducing unittest:
Code (Java)
import static org.junit.Assert.assertFalse;
import com.mindfusion.common.BaseList;
import org.junit.Test;
public class BaseListTest {
    BaseList<Object> sut = new BaseList<Object>() {
    @Test
    public void test() {
        // Given
        final Object o = new Object();
        // When
        final boolean actual = sut.remove(o);
        // Then
        assertFalse(actual);
Re: JPlanner BaseList.remove fails to check presence of item to be removed
Reply #1 - Sep 2nd, 2022 at 8:19am
New build here will return false -
https://mindfusion.eu/Forum/YaBB.pl?num=1660408551
