Normal Topic Custom Shape in React (Read 911 times)
jarv2003
Sep 14th, 2022 at 9:40pm
We use this code to create a custom shape in vb.net.
Private ReadOnly shapeControlValve As Shape = New Shape( _
                                           New ElementTemplate() _
                                           { _
                                               New LineTemplate(100, 35, 50, 50), _
                                               New LineTemplate(50, 50, 50, 25), _
                                               New LineTemplate(50, 25, 5, 25), _
                                               New ArcTemplate(5, 0, 90, 47, -180.0F, 180.0F), _
                                               New LineTemplate(95, 25, 50, 25), _
                                               New LineTemplate(50, 25, 50, 50), _
                                               New LineTemplate(50, 50, 0, 35), _
                                               New LineTemplate(0, 35, 0, 70), _
                                               New LineTemplate(0, 70, 50, 50), _
                                               New LineTemplate(50, 50, 100, 70), _
                                               New LineTemplate(100, 70, 100, 35) _
                                           }, _
                                           Nothing, _
                                           { _
                                               New LineTemplate(100, 75, 0, 75), _
                                               New LineTemplate(0, 75, 0, 100), _
                                               New LineTemplate(0, 100, 100, 100), _
                                               New LineTemplate(100, 100, 100, 75) _
                                           }, _
                                           FillMode.Winding, GlobalModule.ShapeName.SIMValve)
Is there a way to accomplish this in the react version?
Re: Custom Shape in React
Reply #1 - Sep 15th, 2022 at 9:26am
You could add your custom .NET shape definitions to a ShapeLibrary object, call ShapeLibrary.SaveToXml, and load the xml file using respective JavaScript ShapeLibrary.loadFromXml call. After that access shapes by calling Shape.fromId(id).
If you prefer defining the shapes in code, you can use some subset of SVG Path syntax. E.g. here's how the control creates some of its default shapes:
var shapes = [];
shapes.push({ id: "Actor", outline: "M50,20  A10, 10, 0, 0, 1, 50, 0 A10, 10, 0, 0, 1, 50, 20  L70,20  A5, 5, 0, 0, 1, 75, 25  L75,60 L68,60 L68,30 L64,30 L64,100 L52,100 L52,65 L48,65 L48,100 L36,100 L36,30 L32,30 L32,60 L25,60 L25,25  A5, 5, 0, 0, 1, 30, 20  L50,20 Z" });
shapes.push({ id: "Alternative", outline: "M0,100 L50,0 L100,100 L0,100 Z" });
shapes.push({ id: "Arrow", fillMode: "evenodd", outline: "", decoration: "M87,95 L50,0 L13,95" });
for (var i = 0; i < shapes.length; i++) {
    var s = new Shape(shapes[i]);
    s.id = s.params.id;
    Shape.shapes[s.params.id] = s;
