Normal Topic DiagramNode clipping area is not applying when exporting (Read 1621 times)
Dducky
Oct 17th, 2022 at 6:11am
For now, when we creating the diagram node and trying to apply the clip area by override the 'Draw' method - this clipping area is not applying when we trying to export the diagram by SvgExporter.
The code:
In this context the 'node' variable - it is another diagram node that exists under the mask (under the clipping area). We are just trying to apply the clipping area over another diagram node. That works good, but not with svg exporter.
public override void Draw(DrawingContext graphics, MindFusion.Diagramming.Wpf.RenderOptions options)
        var maskBounds = mask.Rectangle.GetBoundingBox();
        var maskRect = DomainUtilities.CreateDomainRectangle(maskBounds);
        var clip = new RectangleGeometry(maskRect);
        graphics.PushClip(clip);
        node.Draw(graphics, options);
        graphics.Pop();
1) The diagram node without the 'clipping area'
2) The diagram node with applied 'clipping area'
3) Check the 'output.pdf' where the exported svg is located.
Re: DiagramNode clipping area is not applying when exporting
Reply #1 - Oct 17th, 2022 at 10:58am
Indeed, SvgExporter does not apply generic clips, as our built-in node types usually draw within their Bounds. We'll try to add some clipping support for next release.
Dducky
Reply #2 - Dec 20th, 2022 at 5:15am
Please, let me know, are you still working on it?
If so, could you please let me know ETA of this feature?
« Last Edit: Dec 20th, 2022 at 10:43am by Dducky »
Reply #3 - Dec 22nd, 2022 at 6:08pm
Try new build here:
https://mindfusion.eu/_beta/wpfdiag39.zip
Clipping is behind a flag at this time; enable SvgExporter.SetClipPaths to test it.
Dducky
Reply #4 - Dec 23rd, 2022 at 6:03am
Its not working as expected with code above. Could you provide any sample how it works with SetClipPaths property?
Also, sometimes when i was trying to export diagram as svg - it cut off parts of some diagram items (without applied mask).
Reply #5 - Dec 23rd, 2022 at 11:20am
Our test code is
class ClipNode : DiagramNode
    public ClipNode()
        var node = new ShapeNode();
        node.Bounds = new Rect(0, 0, 160, 160);
        node.Shape = Shapes.Star16Pointed;
        var maskRect = this.GetLocalBounds();
        graphics.PushTransform(new TranslateTransform(-20, -20));
        graphics.Pop();
        graphics.Pop();
diagram.Nodes.Add(
    new ClipNode { Bounds = new Rect(20, 20, 120, 120) });
diagram.Nodes.Add(
    new ClipNode { Bounds = new Rect(160, 60, 120, 120) });
var svgEx = new SvgExporter();
svgEx.SetClipPaths = true;
svgEx.Export(diagram, "test.svg");
Dducky
Reply #6 - Dec 26th, 2022 at 8:06am
Thanks for sample, but for now SVG node doesn't support clipping area. See the code and attachments.
Light blue background displays the clipping area in 'testSvg.svg' file, the area around this background must be clipped, but it doesn't.
Also you can see the bounds of SVG node and clipping area (see the text in attached testSvg.svg file)
            // Just a SVG node with loaded svg content.
            svgNode.Text = $"Svg node bounds: {svgNode.Bounds} \n Clip area bounds: {clip.Bounds}";
            // 'Clip' bounds is lesser than SVG node bounds.
            // But it doesn't clip the resulting SVG node.
            // The clip area doesn't apply without 'push transform' call, even for shape node.
            graphics.PushTransform(new TranslateTransform(0, 0));
            // Here we are draw the SVG node under the clipping area (but it doesn't apply).
            svgNode.Draw(graphics, options);
            graphics.Pop();
Reply #7 - Dec 26th, 2022 at 9:54am
Apparently the DrawingGroup.ClipGeometry property used by SvgExporter to find clips returns null if there's no transform applied on same element in visual tree (we guess some over-optimization in WPF code), so you will need to keep your fake transform. Our developer will check what happens with embedded SVG.
Reply #8 - Dec 26th, 2022 at 3:32pm
New build here should clip embedded SvgNode too -
diagram.Nodes.Add(
    new ClipNode
        Node = new ShapeNode
            Bounds = new Rect(0, 0, 160, 160),
diagram.Nodes.Add(
    new ClipNode
        Node = new SvgNode
            Bounds = new Rect(0, 0, 200, 200),
            Content = SvgContent.FromFile("img.svg"),
            Transparent = true
    public ClipNode() {}
        if (Node != null)
            graphics.Pop();
            graphics.Pop();
    public DiagramNode Node { get; set; }
Please attach your source SVG drawing if it's still not working for you.
