Normal Topic Can't get Visio2013Exporter to work (Read 1031 times)
Niels
Nov 17th, 2022 at 7:31am
Hi, I need help with the Visio2013Exporter, I can't get it to work.
MindFusion.Diagramming.Export.Visio2013Exporter visioExporter = new MindFusion.Diagramming.Export.Visio2013Exporter();
visioExporter.TemplatePath = @"C:\Users\blabla\Desktop\Visio2013.vtx";
visioExporter.Export(_diagram, @"C:\Users\blabla\Desktop\out.vsdx");
When leaving out the second line, I get an error message saying that the file "Visio2013.vxt" could not be found. Shouldn't it be vtx instead of vxt, as vtx files are Visio templates in XML format?
And where do I get valid vtx files? It seems that I can not generate them from Visio. I tried with different template files (a downloaded vtx, renamed it to vxt, etc.) but always get an "System.IO.IOException: An attempt was made to move the file pointer before the beginning of the file" exception.".
Any help is highly appreciated, thanks! N
Re: Can't get Visio2013Exporter to work
Reply #1 - Nov 17th, 2022 at 8:17am
Try the Redistributable\Visio2013.vxt file from installation. It's not in Visio Template vtx format, but a vsdx one actually, which the exporter uses to recreate all the Visio boilerplate (directory organization in the zip, etc).
Niels
Reply #2 - Nov 17th, 2022 at 8:24am
Thanks, this works very well!
N
