Normal Topic SVG exporter issue (Read 746 times)
nullable
SVG exporter issue
Nov 25th, 2022 at 4:58am
Hello, I have a problem with the svg exporter, for some reason the lines of the exported diagram are thicker than originally, could you check this?
For example, I have the following code with a custom node that draws a rectangle with an ellipse and exports the resulting diagram to SVG, then loads it into a node, changes the position so that the original node overlaps the node with SVG content, but the SVG content node is still visible because its lines are thickener.
var rectangle = new RectangleNode();
rectangle.Bounds = new Rect(0, 0, 300, 100);
Diagram.Items.Add(rectangle);
var svgExporter = new SvgExporter();
svgExporter.Export(Diagram, pathToTempSvg);
var diagramContent = new SvgNode();
diagramContent.Bounds = new Rect(100, 100, 300, 100);
diagramContent.Transparent = true;
diagramContent.ContentAlign = ImageAlign.Stretch;
diagramContent.ContentAutoBounds = true;
diagramContent.SvgUrl = pathToTempSvg;
Diagram.Items.Add(diagramContent);
rectangle.PenBrush = Brushes.Red;
rectangle.ZIndex = diagramContent.ZIndex + 1;
rectangle.Bounds = rectangle.Bounds with { X = 100, Y = 100 };
rectangle.InvalidateVisual();
var rectangle2 = new RectangleNode();
rectangle2.PenBrush = Brushes.Green;
rectangle2.Bounds = new Rect(100, 250, 300, 100);
Diagram.Items.Add(rectangle2);
var rectangle3 = new RectangleNode();
rectangle3.PenBrush = Brushes.Blue;
rectangle3.Bounds = new Rect(100, 250, 300, 100);
Diagram.Items.Add(rectangle3);
public class RectangleNode : SvgNode
        public Brush PenBrush { get; set; } = Brushes.Black;
        public override void Draw(DrawingContext graphics, RenderOptions options)
            graphics.DrawRectangle(Brushes.Transparent, new Pen(PenBrush, 1), Bounds with { X = 0, Y = 0});
            graphics.DrawEllipse(Brushes.Transparent, new Pen(PenBrush, 5), new Point(Bounds.Width / 2, Bounds.Height / 2), 10, 10);
Re: SVG exporter issue
Reply #1 - Nov 28th, 2022 at 10:11am
It should be more precise with new build here -
https://mindfusion.eu/_beta/wpfdiag39.zip
