Normal Topic SVG Parsing inconsistencies (Read 1068 times)
nullable
Dec 29th, 2022 at 8:40am
Hello MindFusion team!
I've faced some inconsistencies when parsing SVG image that I attached. I've also added screenshots, first one is image in browser view, second is image added to a diagram as SVG node. It was loaded on diagram by using SvgContent.Parse method and then set as SvgNode.Content. The problem is that the frame weight is not calculated properly. Could you please investigate?
stream.Seek(0, SeekOrigin.Begin);
var xmlDocument = new XmlDocument();
xmlDocument.Load(stream);
var svgContent = new SvgContent();
svgContent.Parse(xmlDocument, false);
node.Content = svgContent;
nullable
Re: SVG Parsing inconsistencies
Reply #1 - Dec 29th, 2022 at 8:43am
Here is attached file
Reply #2 - Jan 2nd, 2023 at 10:09am
Try this build -
https://mindfusion.eu/_temp/svg_stroke_width.zip
nullable
Reply #3 - Jan 27th, 2023 at 10:29am
Thank you. This one is working. I found another inconsistency with other SVG file. Please test it.
Reply #4 - Jan 31st, 2023 at 8:27am
Try new build here -
https://mindfusion.eu/_temp/svg_subpaths.zip
