Normal Topic Possibilities of size restriction for group nodes. (Read 592 times)
nullable
Apr 10th, 2023 at 1:03pm
Hello.
I want to know if there is possibility to restrict the size to a certain range, when it is attached proportionally to group. For example, I don't want node to grow higher than 20 or below 6 when resizing main group node.
Re: Possibilities of size restriction for group nodes.
Reply #1 - Apr 10th, 2023 at 4:49pm
AttachProportional does not support restricted ranges at this time.You could try using AttachCustom instead, and overriding UpdateGroup to implement your logic.
