Normal Topic Diagramming for JavaScript, V4.2.5 (Read 808 times)
Apr 14th, 2023 at 11:36am
We have released version 4.2.5 of MindFusion JavaScript Diagram library. It contains the following new features and improvements:
Blazor bindings
MindFusion.Diagramming.Blazor allows integrating the JavaScript diagramming API into Blazor applications. It contains a set of .NET wrapper classes, that use Blazor's JSInterop API to create and manipulate the client-side objects. The package provides easy access from C# code to the most of the MindFusion.Diagramming functionality, including different node types, layouts and styling. Additional UI components such as Overview, NodeListView, ZoomControl and Ruler are included too.
  • The opacity property lets you create translucent DiagramItem by applying it to the alpha channel of all colors in the item.
  • Diagram's background image now scales along with zoomFactor.
  • The validateAnchorPoint event validates connecting diagram links to specific anchor points.
  • The validateLinkCrossing event validates visibility of individual link crossing point decorations.
Fixed bugs
  • Fix for mouse wheel not scrolling when virtualScroll is disabled.
  • Touch input fixes.
  • Fix for not raising nodePointed and linkPointed events.
  • Fixed strokeDashStyle XML serialization.
Updated scripts are also available as @mindfusion/diagramming NPM package.
