Normal Topic load Java diagram files? (Read 286 times)
KrzysztofM
Nov 24th, 2023 at 12:03pm
Hi team,
We are looking into building a web viewer companion for our desktop application. Our users will have a bunch of files returned by JDiagram.saveTo method - is there a way to load these into MindFusion JavaScript module?
Thanks!
Re: load Java diagram files?
Reply #1 - Nov 24th, 2023 at 2:33pm
These are based on Java's object graph binary serialization, and unfortunately cannot be loaded in the JavaScript diagram. You should be able to load XML or JSON files though. Maybe add an "Export to Web" command that would save current diagram to one of these formats (e.g. by calling saveToXml), or create a tool to convert all user's files in a batch.
Reply #2 - Nov 24th, 2023 at 2:41pm
... or possibly if server side is in Java, it could create a Diagram instance and convert submitted files on the fly to return XML / JSON to the client side.
