Normal Topic about node select (Read 199 times)
Nobu
about node select
Feb 27th, 2024 at 2:39am
node.selected = true
Executing the above code will result in the following exception
Sometimes it occurs and sometimes it does not, and I do not know the conditions.
    [例外] System.Private.CoreLib.dll!System.ThrowHelper.ThrowInvalidOperationException_Inv
alidOperation_EnumFailedVersion() 行 432  C#
    [例外] System.Private.CoreLib.dll!System.Collections.Generic.List<T>.Enumerator.MoveNex
t() 行 1130   C#
    [例外] MindFusion.Diagramming.dll!MindFusion.Diagramming.Selection.()  不明
    [例外] MindFusion.Diagramming.dll!MindFusion.Diagramming.Selection.Change(MindFusion.Di
agramming.DiagramItem item)    不明
    [例外] MindFusion.Diagramming.WinForms.dll!MindFusion.Diagramming.WinForms.Behaviors.Be
haviorBase.(System.Drawing.PointF )  不明
haviorBase.OnMouseUp(System.Drawing.Point mousePosition, System.Windows.Forms.MouseButtons mouseButton)    不明
    [例外] MindFusion.Diagramming.WinForms.dll!MindFusion.Diagramming.WinForms.DiagramView.
OnMouseUp(System.Windows.Forms.MouseEventArgs e)   不明
    [例外] System.Windows.Forms.dll!System.Windows.Forms.Control.WmMouseUp(ref System.Windows.Forms.Message m, System.Windows.Forms.MouseButtons button, int clicks) 行 12439    C#
    [例外] System.Windows.Forms.dll!System.Windows.Forms.Control.WndProc(ref System.Windows.Forms.Message m) 行 13229    C#
WndProc(ref System.Windows.Forms.Message m)    不明
    [例外] System.Windows.Forms.dll!System.Windows.Forms.Control.ControlNativeWindow.OnMess
age(ref System.Windows.Forms.Message m) 行 67 C#
    [例外] System.Windows.Forms.dll!System.Windows.Forms.Control.ControlNativeWindow.WndPro
c(ref System.Windows.Forms.Message m) 行 117  C#
    [例外] System.Windows.Forms.dll!System.Windows.Forms.NativeWindow.Callback(System.IntPt
r hWnd, Interop.User32.WM msg, System.IntPtr wparam, System.IntPtr lparam) 行 370 C#
    [例外] System.Windows.Forms.dll!System.Windows.Forms.Application.ComponentManager.Inter
op.Mso.IMsoComponentManager.FPushMessageLoop(System.UIntPtr dwComponentID, Interop.Mso.msoloop uReason, void* pvLoopData) 行 346  C#
    [例外] System.Windows.Forms.dll!System.Windows.Forms.Application.ThreadContext.RunMessa
geLoopInner(Interop.Mso.msoloop reason, System.Windows.Forms.ApplicationContext context) 行 1117  C#
geLoop(Interop.Mso.msoloop reason, System.Windows.Forms.ApplicationContext context) 行 981    C#
    [例外] System.Windows.Forms.dll!System.Windows.Forms.Application.Run(System.Windows.For
ms.Form mainForm) 行 1188 C#
    [例外] MainScreen.dll!Messiah.MainScreen.Program.Main() 行 14
Re: about node select
Reply #1 - Feb 27th, 2024 at 7:35am
That could happen if you change selection state from NodeDeselected / LinkDeselected events. In that callstack they are raised within a loop over selection.Items; node.Selected setter modifies that collection, which .NET does not allow during enumeration.
If you are trying to prevent users from selecting or deselecting an item by toggling Selected property after the fact, try handling respective validation event instead, such as NodeSelecting. If you need to copy selection state of an item to other items, try doing that from SelectionChanged event handler, which is raised once for whole selection after the loop.
Nobu
Reply #2 - Feb 27th, 2024 at 8:19am
Thank you for your response.
I will try it.
Nobu
