Normal Topic Compilation error (Read 14046 times)
Janice
Compilation error
Dec 14th, 2009 at 5:53pm
I just installed the MindFusion.Diagramming software. However, whenever i compile it. An error occur. May i know how can i solve it? Thank a lot for help!  Smiley
the error message is
"Exception occurred creating type 'MindFusion.Diagramming.Wpf.Diagram, MindFusion.Diagramming.Wpf, Version=2.2.1.21612, Culture=neutral, PublicKeyToken=1080b51628c81789' System.TypeLoadException: Could not load type 'System.Windows.Media.Effects.Effect' from assembly 'PresentationCore, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'."
Re: Compilation error
Reply #1 - Dec 14th, 2009 at 7:19pm
It requires version 3.5 of the .NET runtime. If you have it, make sure the runtime target version in the project properties window is set to 3.5.
Janice
Reply #2 - Dec 15th, 2009 at 3:23pm
Hi, Stoyan,
I'm using Microsoft visual studio 2008 with the microsoft .net framework version3.5. May i know how to check the runtime target version?
Thank you!  Smiley
Reply #3 - Dec 15th, 2009 at 4:04pm
Right click the project in Solution explorer and select Properties. In the Application tab you can find a "Target Framework" drop down list that shows the available versions. Select .NET 3.5 and it should run fine. Is it some of the sample projects coming with the control that does not compile successfully?
Janice
Reply #4 - Dec 15th, 2009 at 5:07pm
My current "Target Framework" already in .NET 3.5, the problem still exists. By the way, I already try most of them, all having the same error message.  Embarrassed
Janice
Reply #5 - Dec 15th, 2009 at 6:27pm
Now I wonder if this Effect class didn't appear in service pack 1 of the V3.5 runtime. Could you install .NET 3.5 SP1 and check if the problem persists?
