Normal Topic Using Dock problems (Read 6160 times)
jackalexander
Using Dock problems
Sep 24th, 2011 at 6:02am
Have just started using MindFusion and started with a simple dock project.  The given sample works fine, but I want to do it in XAML.  I can't see why the following does not work - can anyone help please?
( I expect to see an output panel at the bottom and two docked panels to the left.  But the two left panels are not docked together).
           <ui:DockItem Header="Toolbox"
                        Name="toolboxwindow"
                        CanDock="True"
                        Priority="1">
               <ListBox></ListBox>
           </ui:DockItem>
           <!-- bottom output window -->
           <ui:DockItem Dock="Bottom"
                        Header="Output"
                        Name="outputwindow"
                        Priority="2">
               <ScrollViewer HorizontalScrollBarVisibility="Auto"
                             VerticalScrollBarVisibility="Auto">
                   <Border>
                       <TextBlock></TextBlock>
                   </Border>
               </ScrollViewer>
           </ui:DockItem>
           <!-- docked to toolbox -->
           <ui:DockItem Header="Resources"
                        Name="resourcewindow"
                        DockTarget="{Binding ElementName=toolboxwindow}"
                        Priority="3">
               <ListBox></ListBox>
           </ui:DockItem>
Re: Using Dock problems
Reply #1 - Sep 24th, 2011 at 10:15am
Docking items together did not work from Xaml indeed. On the private messages page you can find a new MindFusion.UI.Wpf.dll build that should fix that.
jackalexander
Reply #2 - Sep 25th, 2011 at 8:20am
Thnaks, but how do I get to the private messages page please. ???
Reply #3 - Sep 25th, 2011 at 9:56am
There is a link to it at the top of the forum page, saying that you have a message.
jackalexander
Reply #4 - Sep 25th, 2011 at 12:30pm
Ah - missed that - thank you
