Normal Topic WinUI 3 Diagram control preview (Read 5936 times)
Jul 29th, 2024 at 7:13am
We are beta-testing a WinUI 3 version of the MindFusion.Diagramming library. If anyone is interested in trying it out, please install it from:
https://www.nuget.org/packages/MindFusion.Diagramming.WinUI/
In order to create a Diagram in Xaml, import the MindFusion.Diagramming namespace:
<?xml version="1.0" encoding="utf-8"?>
<Window
    xmlns:diag="using:MindFusion.Diagramming">
	<Grid>
		<ScrollViewer HorizontalScrollBarVisibility="Auto">
		    <diag:Diagram x:Name="diagram" />
		</ScrollViewer>
	</Grid>
</Window>
The initial release implements the same API as our WinRT / UWP control, documented at http://www.mindfusion.eu/onlinehelp/diagramrt/index.htm :
public sealed partial class MainWindow : Window
    public MainWindow()
        this.InitializeComponent();
        diagram.Bounds = new Rect(0, 0, 5000, 5000);
        var node1 = diagram.Factory.CreateShapeNode(30, 30, 90, 90);
        node1.Text = "Hello";
        var node2 = diagram.Factory.CreateShapeNode(180, 75, 90, 90);
        node2.Text = "WinUI!";
        diagram.Factory.CreateDiagramLink(node1, node2);
A sample project is available here:
https://mindfusion.eu/DiagramWinUI.zip
We do not support C++ binding at this time. This will be added upon request.
