Normal Topic Move shapes with arrow keys (Read 2808 times)
himpact
Dec 12th, 2011 at 4:53am
Its there away to move the selected node(s) using the keyboard arrow keys?
HL
Re: Move shapes with arrow keys
Reply #1 - Dec 12th, 2011 at 6:55am
By default the framework does not raise KeyDown event for the arrow keys but PreviewKeyDown, so you can move nodes like this:
private void diagramView_PreviewKeyDown(object sender, PreviewKeyDownEventArgs e)
	if (e.KeyCode == Keys.Left)
		DiagramNode node = diagram.ActiveItem as DiagramNode;
		if (node != null)
			RectangleF bounds = node.Bounds;
			bounds.Offset(-5, 0);
			node.Bounds = bounds;
himpact
Reply #2 - Dec 13th, 2011 at 7:02am
Thank-You!!!
