Normal Topic Change Zoom Client Side (Read 1410 times)
rlira
Dec 21st, 2011 at 6:06pm
Hello!
I have a select on the html with values for the user to zoom in or out the diagram without having to go to the server.
Based on my own previous questions and what I've found on online help I came up with the following:
    function setZoom()
	  var applet = <%= diagramView.AppletElement %>;
	  applet.setZoomFactor(100);
However I get an error telling the the method isn't supported.
Is the method inside some other object?
Thanks in advance.
Re: Change Zoom Client Side
Reply #1 - Dec 21st, 2011 at 6:13pm
applet is an instance of the DiagramApplet class. Call its getDiagramView() method to get an object of type DiagramView, which implements the ZoomFactor property.
rlira
Reply #2 - Dec 21st, 2011 at 6:25pm
That is extremely helpfull!!
Thanks a lot!
