Normal Topic Creating a diagram with a minimum size   (Read 2295 times)
jlj30
Nov 30th, 2011 at 6:23pm
I am using diagram.ResizeToFitItems, but would like to ensure that the diagram meets a certain "minimum" size requirement.
Any suggestions?
Jim
Re: Creating a diagram with a minimum size
Reply #1 - Nov 30th, 2011 at 6:28pm
Try this:
diagram.Bounds = RectangleF.Union(minBounds, diagram.GetContentBounds(false, false));
jlj30
Reply #2 - Nov 30th, 2011 at 7:16pm
Although this looked promising (after I took note of what Union did), it did not address my issue.  I tried it before and after the ResizeToFitItems with no difference in result.
Perhaps I need to explain that I am using "swim lanes", and that I really need the first (and only) column to be a minimum width regardless of the number of shapes placed in the lane.
In essence, I'd really like to make the column header a minimum width - much like "MinHeaderSize" which seems to only address the height of a column header.
Jim
Reply #3 - Dec 1st, 2011 at 8:05am
I think the column width stays fixed, as set through to the Width property of the column header. However if you are using SwimlaneLayout, it might be resizing the column to fit the nodes inside. If you want the grid to have some minimum size in such case, you will have to reset header.Width after applying the layout if you detect it got smaller than the min.value.
