Normal Topic SaveToPNG image size (Read 4336 times)
binuvc
Jan 31st, 2012 at 3:16pm
The size of the png stream obtained on invoking SaveToPNG is increasing to more than 8 mb and sending the image to serverside is becoming an issue.
Do we have any compressioin routines using which we can reduce the size?
Please advice.
BinuVC
Re: SaveToPNG image size
Reply #1 - Jan 31st, 2012 at 5:46pm
There are no image encoders provided with the Silverlight runtime and there's no built-in compression in DiagramLite. You will have to use a third party library to create compressed images. E.g. the code below creates a jpeg image using the Silverlight ImageTools library from http://imagetools.codeplex.com/:
private void OnExport(object sender, RoutedEventArgs e)
	var bitmap = diagram.CreateImage();
	var image = ImageExtensions.ToImage(bitmap);
	var dlg = new SaveFileDialog();
	dlg.DefaultExt = ".jpg";
	if (dlg.ShowDialog() == true)
		var stream = dlg.OpenFile();
		var encoder = new JpegEncoder();
		encoder.Encode(image, stream);
		stream.Close();
binuvc
Reply #2 - Feb 1st, 2012 at 4:22am
Thanks !!
BinuVC
