Normal Topic SwimLane Layout CollapseEmptyLanes = false not working (Read 3805 times)
binuvc
Apr 27th, 2012 at 10:30am
While applying a swimlane layout, we have explictly specified
layout.CollapseEmptyLanes = false
But still the empty lanes are getting collapsed.
Following is the layout apply code
    SwimlaneLayout layout = new SwimlaneLayout();
            layout.Anchoring = Anchoring.Ignore;
            layout.CollapseEmptyLanes = false;
            layout.CompactNodes = false;
            layout.Direction = MindFusionLayout.Direction.Straight;
            layout.KeepGroupLayout = false;
            layout.KeepLaneSizes = true;
            layout.LaneDistance = 150;
            layout.NodeDistance = 50;
            layout.Orientation = MindFusionLayout.Orientation.Horizontal;
            layout.Margins = new Size(
                     diagramLite.LaneGrid.GetRowHeaderBounds().Width,
                     diagramLite.LaneGrid.GetColumnHeaderBounds().Height);
            layout.Arrange(diagramLite);
            var rect = diagramLite.LaneGrid.GetColumnHeaderBounds();
            rect.Union(diagramLite.LaneGrid.GetRowHeaderBounds());
            diagramLite.Bounds = rect;
Please advice
BinyVC
Re: SwimLane Layout CollapseEmptyLanes = false not working
Reply #1 - Apr 27th, 2012 at 1:21pm
Can you attach a small sample illustrating the collapsing lanes? I am trying to reproduce this bug, but it appears to work as expected.
binuvc
Reply #2 - Apr 27th, 2012 at 1:32pm
I just debug the code and found that in the above listed code, the number of LaneGrid.RowCount is 7( 5 has nodes associated with it) and after the arrange method is executed, the LaneGrid.RowCount is 5. looks like the 2 lanes with no associated nodes are not incuded. But if I add a node to each lane, it works as expected
I am using 2.3.0.16641 trial version of diagramlite.
BinuVC
Reply #3 - Apr 27th, 2012 at 2:01pm
This is actually by design. The empty rows at the end are removed by the swimlane layout. One way to avoid this is to add invisible nodes to these rows. Another solution would be to use a custom swimlane grid that ignores the call that sets the row count. Here is a sample implementation of such grid:
class SwimlaneGrid : ISwimlaneGrid
	public SwimlaneGrid(MindFusion.Diagramming.Silverlight.Lanes.Grid laneGrid)
		this.laneGrid = laneGrid;
	public int GetColumnCount()
		return laneGrid.ColumnCount;
	public double GetColumnWidth(int index)
		return laneGrid.ColumnHeaders[index].Width;
	public int GetRowCount()
		return laneGrid.RowCount;
	public double GetRowHeight(int index)
		return laneGrid.RowHeaders[index].Height;
	public void SetColumnCount(int value)
		// Do nothing to prevent columns from being dropped
	public void SetColumnWidth(int index, double value)
		laneGrid.ColumnHeaders[index].Width = value;
	public void SetLeftMargin(double value)
		laneGrid.LeftMargin = value - laneGrid.GetRowHeaderBounds().Width;
	public void SetRowCount(int value)
		// Do nothing to prevent rows from being dropped
	public void SetRowHeight(int index, double value)
		laneGrid.RowHeaders[index].Height = value;
	public void SetTopMargin(double value)
		laneGrid.TopMargin = value - laneGrid.GetColumnHeaderBounds().Height;
	private MindFusion.Diagramming.Silverlight.Lanes.Grid laneGrid;
To associate this grid with the layout, use the following line:
layout.SwimlaneGrid = new SwimlaneGrid(diagram.LaneGrid);
Keep in mind that the last solution will not work with all layout settings.
I hope this helps.
binuvc
Reply #4 - Apr 27th, 2012 at 4:29pm
Many Thanks !!
BinuVC
