Normal Topic Restrict movements of shape node (Read 2302 times)
Gautham
May 15th, 2012 at 12:50pm
How do i restrict the movements of shape node, so that it cant be moved off the screen or within keep the movement within visual bounds
Re: Restrict movements of shape node
Reply #1 - May 15th, 2012 at 5:56pm
You could handle the NodeModifying event like this:
if (!diagram.Bounds.Contains(e.Node.Bounds))
    e.Cancel = true;
