Normal Topic Cut/Paste didn't work for group nodes (Read 2916 times)
softsara
Jul 3rd, 2012 at 12:06pm
dgDiagram.CutToClipboard(false);
This method call doesn't copy the group nodes. Short cut Ctrl + X also doen's copy the group nodes.  Embarrassed
How to do it?
Re: Cut/Paste didn't work for group nodes
Reply #1 - Jul 4th, 2012 at 7:12am
We'll add a new CutToClipboard overload that copies groups for the next release. For the time being, you could use the CopyToClipboard overload that takes a 'groups' parameter to copy the grouped nodes, and then remove the nodes from the diagram.
softsara
Reply #2 - Jul 4th, 2012 at 2:21pm
Thanks Smiley. In that case, how to disable the Ctrl + X feature?
Reply #3 - Jul 5th, 2012 at 8:56am
You can override the default Cut command binding like this:
diagram.CommandBindings.Add(
	new CommandBinding(ApplicationCommands.Cut, (sender, args) => MyCutMethod()));
Pass an empty lambda expression to disable Ctrl+X altogether.
