Normal Topic LegendLabels values overlapped (Read 5818 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Sep 7th, 2012 at 9:14am
Dear Stoyan,
     i am not able to wrap the LegendLabels property, it is getting overlapped
currently i have 14 columns but soon i will have around 50. kindly help
my code follows
int[] tcount = new int[count];
                string[] vname = new string[count];
                for (int i = 0; i < count; i++)
                    tcount[i] = Convert.ToInt32(ds.Tables[0].Rows[i]["total_count"]);
                    vname[i] = (ds.Tables[0].Rows[i]["village_name"].ToString());
                BarChart1.Data = tcount;
                BarChart1.XLabels = vname;
                BarChart1.LegendColumns = count;
                BarChart1.LegendLabels = vname;
                BarChart1.LegendWordWrap=true;
                //BarChart1.PieceOutIndex = 0;
                //BarChart1.PieceOutPercent = 60;
                BarChart1.TitleText = "Pregnant Women anemic-" + phcs;
                //Brushe
                BarChart1.ChartBrushes[0] = new MindFusion.Drawing.PathGradientBrush("#FFFFFFFF;#FFFF8080;0;0;0;0;");
                BarChart1.ChartBrushes[1] = new MindFusion.Drawing.PathGradientBrush("#FFFFFFFF;#FFFF8080;0;0;0;0;");
if you want something then go and grab it
Re: LegendLabels values overlapped
Reply #1 - Sep 7th, 2012 at 12:50pm
Are you trying to break the legend labels into several rows? This is possible, but it is not done with the LegendWordWrap property. LegendWordWrap breaks a long legend label into smaller text lines and will work if labels contain more than one word. Try this if you want to have legend labels arranged in a table of several rows and columns:
barChart1.LegendColumns = 10;
barChart1.LegendWidth = 600;
Setting columns to 10 as above will arrange 50 labels in 5 rows. If you don't specify LegentWidth explicitly, the max. width of the legend box will be equal to the width of the chart and that might not be enough to fit all labels.
You could also try rotating the axis labels to prevent them from overlapping:
barChart1.XAxisSettings.RotationAngle = 30;
madhan1
FROM EVERY ONE ..
Reply #2 - Sep 10th, 2012 at 12:56pm
Thanks stoyan.
