Normal Topic integer value in line chart (Read 7006 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Sep 21st, 2012 at 9:38am
Dear stoyan,
           i am facing the format error for number.
i am binding {100,200}.
but it is displaying {100.00,200.00} in yaxis
the code i am using is
for loop
data[i] = Convert.ToInt32(ds.Tables[0].Rows[i]["int_totalcalls"].ToString());
LineChart1.YAxisSettings.DataFormat = MindFusion.Charting.DataFormat.Number;
                    LineChart1.YData = data;
kindly help
if you want something then go and grab it
Re: integer value in line chart
Reply #1 - Sep 21st, 2012 at 10:30am
This will draw numbers without the decimal part:
LineChart1.YAxisSettings.NumberFormat = MindFusion.Charting.NumberFormat.Fixed_point_0Digits;
madhan1
FROM EVERY ONE ..
Reply #2 - Sep 21st, 2012 at 10:43am
Thanks stoyan,
                 it works fine
