Normal Topic creating my own Recurrence form (Read 3010 times)
ricardo
May 9th, 2013 at 4:02pm
Hi
I created my own recurrence form, but I have a problem with weekly intervals, the DaysOfWeek values is always None, can you check why my code is not working?
here is the code:
  recurrence.Pattern = RecurrencePattern.Weekly;
                    recurrence.Weeks = Convert.ToInt32(txtWeeks.Text);
                    recurrence.DaysOfWeek = DaysOfWeek.None;
                    if (radMonthlyDay01.IsChecked == true)
                        recurrence.DaysOfWeek = recurrence.DaysOfWeek | DaysOfWeek.Monday;
                    if (radMonthlyDay02.IsChecked == true)
                        recurrence.DaysOfWeek = recurrence.DaysOfWeek | DaysOfWeek.Tuesday;
                    if (radMonthlyDay03.IsChecked == true)
                        recurrence.DaysOfWeek = recurrence.DaysOfWeek | DaysOfWeek.Wednesday;
                    if (radMonthlyDay04.IsChecked == true)
                        recurrence.DaysOfWeek = recurrence.DaysOfWeek | DaysOfWeek.Thursday;
                    if (radMonthlyDay05.IsChecked == true)
                        recurrence.DaysOfWeek = recurrence.DaysOfWeek | DaysOfWeek.Friday;
                    if (radMonthlyDay06.IsChecked == true)
                        recurrence.DaysOfWeek = recurrence.DaysOfWeek | DaysOfWeek.Saturday;
                    if (radMonthlyDay07.IsChecked == true)
                        recurrence.DaysOfWeek = recurrence.DaysOfWeek | DaysOfWeek.Sunday;
is there any method to assign values individually accumulating them?
Re: creating my own Recurrence form
Reply #1 - May 9th, 2013 at 5:43pm
I think the DaysOfWeek property setter doesn't let you assign the None value to it at all and just returns, are you sure it shows None? You will have to accumulate the bits in a separate enum DaysOfWeek variable, and assign the final result to the property. Otherwise any bits that were set in the previous property value will remain, and your code will just be adding new ones (so you might be seeing the All value actually?).
