Normal Topic ItemResources, GroupByResource and timetablesettings work time start (Read 4216 times)
Dom@Hadley
Oct 5th, 2017 at 2:57pm
Hi
I have two resources which I've grouped the calendar by. What I would like to know is if it's possible for the resources to have different work times on the same calendar lane? calendar is in timetable view
Cheers
Re: ItemResources, GroupByResource and timetablesettings work time start
Reply #1 - Oct 6th, 2017 at 8:08am
You cannot do this out-of-the-box, but it is easily achievable by using a combination of custom resources and custom presenters for the cells in the view. The following sample illustrates how:
https://mindfusion.eu/_temp/_sample_CustomTimetable.zip
The sample goes even further by providing the ability to define multiple work intervals for each resource.
Let me know if this helps.
Dom@Hadley
Reply #2 - Oct 6th, 2017 at 10:45am
Hi Meppy
Many thanks for your reply. I tried this out but found that the whole thing disappears as soon as you set ShowCurrentTime. I think it might be more fiddly than it merits so I've adjusted it to show the earliest resource time and the latest resource time as the total working time for the planner. The timings are also different for each day which is something else I need to think about.
Cheers
Dom
Reply #3 - Oct 12th, 2017 at 7:45am
I don't see any problems when I set ShowCurrentTime. What do you mean by "the whole thing disappears"?
